Albert Noel
The press is a 2006 Speedmaster SM74. The press itself runs great and the feed seems bullet-proof, except this issue we seem to have on 19x25" sheets. It happens on all text weights (and happens less frequently on anything heavier then 80# gloss or 70# uncoated text) The corner of the sheet about a half inch in from either edge looks as thought it's catching on something at a very fine point and it either tugs the sheet enough to crease/wrinkle/double on the next sheet, or it just folds the corner over (assuming it is somehow hitting an indeed gripper either in the swing arm or the very first transfer drum)
We've checked, checked and checked again all the grippers as well as the front lays and headstops. everything seems to be functioning correctly and nothing seems broken or out of the ordinary. We have had several outside people look at it (two separate techs from Heidelberg, a demonstrator, and a third party tech) all who cannot figure it out. One of the Heidelberg techs claim something must be out of sorts or broken, the other claims that it is a design flaw in that particular year, the demonstrator says its just the way the paper is positioned (and to run everything off centre) and the third party tech thinks we need to replace the infeeed swing gripper.
I'm mostly just wondering if anyone else has experienced this before on their SM74 (2006 model or similar)
