Hello, We have a Ryobi 3304HA and love it. for most of the time we've had it, got it new bout 5 years ago, we've had issues with the first two units showing a little tail whip. We run small color dots along the tail with one of each at 50% screen. You can see slight "ghosting" side to side on the tail every other one. Tech guys have tried resetting grippers, cam followers, timing etc... we do run four color envelopes which sometimes makes it a little worse, but checking and settine grippers usually gets in back to "normal": which is still not right. This is driving everyone here crazy obviously cos it affects color consistency form head to tail. our press tech has a throry that settling has made the two halves of the press "twist" slightly, so he' is coming in tuesday to unblot and re bolt and level the press. I"m skeptical but at a loss for any other direction to go. Has anyone had this experience with the 3304HA and managed to correct it? I"d love to know what you did...We're starting to suspect a design flaw....(grasping at straws here)...
thanks
Sean in Louisiana
thanks
Sean in Louisiana
