We recently have acquired a project because of problems with their existing printer. The main problem is that a large number of their pieces are arriving damaged. The cards go presort standard, across several states. The damage our customer showed us looks to me like friction from a roller from the mail sort machine...like the postcard is getting stuck in the machine and its spinning its roller on the print, creating heat which distorts the toner.
You know as well as I do that junk mail ends up in the trash within a few seconds and we can't control what happens at USPS. But we have the opportunity to try to solve this problem, so that's why I'm asking for suggestions.
We have done a few of these mailings over the last couple weeks and the results have come back...that we, and another printer (who they are also auditioning for the job), also have the same problems when we mail out the cards. Disappointing but not really surprising...we didn't expect the problem to be at the printer level based on its appearance.
The card is printed on 270gsm 12pt C2S, on a Xerox J75. No idea what the other printers are using, but they should be using the same weight stock. Cuts to 8.5x5.5 so basically counts as a letter. We dropped it at a post office in the middle of the country, they dropped it on the coast. List goes to several different states ultimately. So not specific to one post office. Card is not UV coated, but we may try mailing a few out UV coated to see if it makes a difference. I suspect that maybe the stock is a little thick for the mail sort machine and its threshold isn't opening enough. The J75 uses a low melt toner so I could see how it could melt with friction.
This is by far not our first post card mailing but honestly can't say that anyone has ever come back to complain about what the product looks like once it has been through the mail. Though offhand don't remember when the last time someone has requested to use 12pt C2S for their postcard.
