Ab dick 9870 dampening system
jonetacache
Hello,
Am hoping to have some info on the replacement of the rubber roller on the Super aqua Dampening System that my 9870 came with. I have never changed anything on this machine but knew that the rubber pan roller was going bad, so I have the roller, but not sure how to go about in taking this apart, or is it just a matter of loosening some screws and Bang its out, would like to hear any thoughts, and Thanks for the Help!!!
John
1. You should be able to figure out how to remove/replace it by studying the parts manual.
2. Try contacting the vendor that will be selling you the replacement.
3. Just hang out on this forum, and with luck, some one will post the answer you need.
9870
9870
Check out pt1225
Sign up and get the help you need. Many expert techs are there to help you. They specialize in AB Dick Presstek Hamada Multi Ryobi with full service manuals and phone support.
Good luck
CYMK
9870 dampening roller
Hello - did you get your roller fixed? I have almost every AB Dick model press, and can help you with many repairs if necessary. Let me know if I can help.
Bill G
how about a recomendation for a dampening system for a 9995. Looking at both Kompac and Crestline. Does one work better than the other???
Dampening system
Dampening system
Hello Darton,
The 9995 is a Ryobi press. I believe both Kompac and Crestline make dampening systems. Both are good.
BG
