Auto-balance error CTP
craveiro
Auto-balance lets you use different sized plates without making any manual adjustments for correct drum balance, when i use the small plates the auto-balance gives error...away balancer! I need to reset the correct parameters on the machine manually to be able to print the larger plates! When I put the smaller ones back on it happens again...
