Baldbug
We installed an Acento IIs 2 years ago and have had no probs with Acento. The Azura C95 is another issue. We've done 3 control panels, replaced all the fuses with slow blow fuses, the plate transfer table with the red rubber bands keeps jamming the plates on exit from CTP. Very fine adjustment to fix this mostly. Heater over heats, now fixed. Cracked plastic seals on fixer pump lines causing air to be introduced to the lines. noisey rattley fan assembly.
What else is likely to fail on this piece of equipment
regards
Rod
regards
Rod
