I believe RGPW's observation about the Azura "gum" put's this whole debate into perspective.
Since Azura's launch in 2004, the debate over semantics has largely been quieted, based on
actual use in the field. As GreenPrinter also notes, it's better to contain the emulsion removal,
rather than having this possibly contaminate the press chemistry. Azura's core Thermofuse
technology was first launched in 2000 as an on-press imaging plate, where the emulsion was
pulled off after wetting, and deposited on the first few sheets. Sound familiar? Based on the
limitations of this process, and the limitations that some press architectures imposed, Agfa
rolled-out the Azura implementation with the preservative gum as the only "chemical". This
has proven in over four years of use to be a practical application serving a wide latitude of
conditions. Yes, as RGPW notes, one could use water, and the plates would clean-out and
roll-up and print fine. The gum acts not as a developer, but rather a traditional oxygen
barrier to prevent oxidation, beyond what simple water could do as a clean-out. The imaging
process of Azura is purely physical, dependent on no chemical interaction to help define proper
exposure. And, the plates are not white light sensitive (under practical conditions), so there is
no need to mount on press within a short time frame, nor shield in dark boxes or bags.
If one is interested - "Santa" has been posting here for 4 years on this subject. Search
his comments for more real-world opinions on its use. Thanks to RGPW & GreenPrinter's
real-world responses as well.
Regards,
