ruthndul
Looking for expert advice here.
We have banding problem.
a job that previously been done on offset press with Pantone 653U (uncoated) (see 2nd sample from the left)
now done on digital (see 3rd sample from the left)
We did our best to match their business card which was done on coated, Pantone was adjusted to 653C.
However, customer doesn't like the pinkish gradient on the lighter side (circled).
The job was tried to be redone on the offset press.
Another problem occurred : banding (see first sample from the left).
Things I've done and didn't work
- convert the gradient to bitmap in photoshop
- adding gaussian blur and noise to the bitmap in photoshop
- rotate 90 degree when outputting to plate
- rotate gradient 1 degree
- increase line screen from 150lpi to 175lpi
- reduce the max gradient from 100% to 90%
The last one (4th from the left),
I created a bunch of blending objects to ease of the gradient computation while reducing the magenta amount on the lighter side.
We haven't try to output the last one to plate, as the original is only one spot colour, and for digital output purpose, I convert it to CMYK.
File was created in Indesign CS6
exported to PDF for output
Digital : Xerox 700
Offset : Itek 3395 2 color
Plate maker : Agfa Avantra 25 - polyester plate
RIP : Harlequin
Any ideas how to solve this problem ?
Thank you
Digital : Xerox 700
RIP : Harlequin
Thank you
