fast impose swings the pages using 2 factors. One is put in the bottling tab on the sig. the other is a factor in the impose itself. What I have done is counted the right angle folds on a printed sample. Then added that number in the sig. When I make the impose I add a bottling factor. In the paperwork from Esko, the example of this factor is 1.2. With hole numbers in the sig (1 for outside spreads, & 16 for center spread). it swings the pages by inches. In experementing, I add .0026 to the factor and get about .0625 swing on the center spread. On the outside spread the swing is .004. this will work for this stock. We use many stocks and would have to use trial and error to find the correct factor for each stock. I was wondering what numbers you use in the sig. and the factor used with it.
