CIP3 ink order for double web
lnivin
Using Prinergy PrintLink to create CIP3 files, the ink order is writing as
Sig A (2,3,4,1) | Sig B (2,3,4,1) | Sig C (6,7,8,5) | Sig D (6,7,8,5)
What we need is
Sig A (6,7,8,5) | Sig B (6,7,8,5) | Sig C (2,3,4,1) | Sig D (2,3,4,1)
I've tried the Print Interface Configuration File coding of "SwapFrontswithBacks=true", but it didn't work. Then tried "AlwaysFront=true", also didn't work.
At the moment, they are able to assign at the press.
I appreciate any help with this.
Thank you,
Linda Nivin
Morning
Its been a while but i believe the ink order is set in your preferences by defining the "zones" and zone width, reverse the order of yuor set prefernces and see if this works for you
regards
Maas
