CTP - delhi
shobhit13
Hi guys
I have a small offset setup in delhi and m planning to install a CTP
can you guys help in suggesting me a cheap and best CTP and i dont want 2nd hand machine
rgds
You will need to understand run lengths, plate minimum and maximum size requirements, quality, number of plates needed per hour and day, and then decide on poly, or metal either thermal or violet. If you are looking for metal there are 4 links below to companies that have lower cost as well as smaller format CTP.
ECRM Mako ECRM Imaging Systems - Commercial Printing
Heidelberg Heidelberg - Computer-to-Plate Overview
Printware Platestream PlateStream Violet
Presstek Presstek CTP Systems Overview
There also are metal inkjet systems by my testing has not been good and worth the low investment cost to be able to produce a lower quality print.
G&J iCtP iCtP
JetPlate JetPlate Systems
hi
tks for the reply
i m looking for metal plates and also i m in an impression that violet last long as compared to the thermal.
I would require a CTP with 18"x23" (paper size) machine and
slow but cost effective would do as plates per hr is not an issue with us
can we now be a bit specific
tks 1ce again
