Curl on edge of gatorboard using arlon dpf-4500glx
EricD
DPF 4500GLX / MLX | North America <---This is the material we are using.
Some times it does not cural and others it does. I wait 24 hours before putting it on the board. The curl happens over time usually. Suggestions on some kind edge sealer. I am using an MimakiJV 100-160 printer. Thank you for any help you can suggest.
Eco sol inks make some vinyls edge curl unless you laminate them.
Interesting. I am new to this whole process. Is there some vinyl you know of that would work with our Mimaki that inks do not have that effect on.
