JMD Print Finishing
PUR (Polyurethane Reactive) adhesive is a moisture-curing reactive polyurethane hot melt adhesive, which is a polymer compound with urethane bonds. Its molecular chains have isocyanate groups at the ends, and when these groups encounter moisture in the air, they undergo an irreversible crosslinking reaction, forming a solid adhesive layer. This is the unique characteristic of PUR adhesive, which allows it to bond various materials effectively, including lacquered surfaces, UV-cured layers, plastic films, and coated paper.
PUR adhesive demonstrates excellent bonding strength across different paper stocks and materials, particularly for difficult-to-bond coated papers. After application and drying, the adhesive maintains good flexibility at both high and low temperatures. The curing time varies depending on external conditions - generally, 50-80% of bonding strength is achieved within 6 hours. Full curing depends on factors such as air humidity, paper moisture content, adhesive layer thickness, and material penetration characteristics, with complete bonding typically achieved within 48 hours. It's important to note that once PUR adhesive solidifies, it cannot be re-melted, which is why sufficient curing time must be allowed before shipping or handling bound materials.
KEY ADVANTAGES:
1. Superior Bonding Properties
PUR adhesive can firmly bond various types of coated papers together, which is primarily due to the polar nature of polyurethane molecules that allows excellent bonding with coated layers. The bonding strength is largely unaffected by paper weight variations, and regardless of the coatings or inks used, the adhesive performs consistently. When performing pull tests on 200g/m² coated paper, the paper itself tears before the adhesive bond fails, demonstrating exceptional bonding quality. For publications requiring long-term preservation (PUR durability exceeds 100 years), PUR binding is an ideal choice.
2. Cold and Heat Resistance
For books or maps stored in harsh environments - such as those left in vehicles during summer heat or exposed to cold winter conditions - temperature resistance is critical. PUR-bound books are essentially unaffected by temperature extremes and maintain their integrity in challenging environmental conditions. Since PUR adhesive cannot be re-melted once solidified, issues like page separation, loose pages, or brittleness do not occur.
3. Enhanced Spine Flatness
The application thickness of PUR adhesive is generally much thinner than standard EVA hot melt adhesive layers, resulting in minimal adhesive squeeze-out at the encasing station. The clamping plates firmly secure the cover to the book block, creating a well-defined spine. Additionally, the PUR adhesive layer maintains some degree of extensibility and flexibility during the drying process. Since PUR operates at a lower working temperature (around 120°C), paper moisture is retained during adhesive application, allowing paper fibers to recover. These properties enable PUR-bound books to lay flat when opened without manual pressing, improving reader comfort. This makes PUR binding particularly suitable for reference books, manuals, cookbooks, and other publications requiring flat-opening characteristics.
4. Cleaner Trimming Edge
Since PUR adhesive application thickness is only half that of EVA adhesive, there is no thick material buildup at the trimming knife, preventing uneven cuts. The trimmed edge is smooth without stepped edges, and the book edge margins are more uniform.
5. Strong Solvent Resistance
PUR adhesive is a binding material that resists both solvents and oils. Cured PUR material can penetrate into printing inks and solvents. Traditional binding materials can gradually soften or even dissolve when exposed to certain chemicals, significantly reducing binding quality. This makes PUR particularly valuable for technical manuals and industrial publications that may be exposed to various chemicals.
INDUSTRY OUTLOOK:
As PUR adhesive continues to gain adoption and awareness in the binding industry, its usage is growing exponentially. This growth is accelerating domestic production capabilities. If PUR adhesive pricing can be controlled at reasonable and acceptable levels in the future, combined with its environmentally-friendly characteristics that do not harm the environment, it will become even more favorable for waste paper recycling and secondary utilization.
The environmental benefits are significant - PUR adhesive does not release harmful substances during use and poses no health risks to operators. Its contribution to sustainable practices makes it an increasingly attractive option as the industry moves toward more eco-friendly production methods.
I hope this technical overview is helpful for those considering or working with PUR binding systems. Has anyone here had experience with PUR versus traditional EVA adhesives? I'd be interested to hear about practical experiences and any tips for optimal results.
KEY ADVANTAGES:
INDUSTRY OUTLOOK:
