Darwin & DirecType
jcbugs
First Post here, about time. I work for an offset printer and we recently purchased a NexPress 2500. Along with this we bought Darwin so that we could dive head first into variable data. Well, along the way a salesman thought that DirecType was the perfect solution for personalized images. Well needless to say, support from Kodak (for a product they say they support) is next to none, alot of exchanged emails with no solid answers. Any thoughts on the combined operation of these 2 programs would be greatly appreciated. Specifically having problems with naming images in DirecType to match lookup files that are generated in Darwin. Thank You
Darwin and DT integration
In case you are using Darwin Pro on a PC, you have a direct integration with DT.
Attached is a document explaining this integration.
If this is not the case, you can reply here or send me an email directly.
Best regards,
Ron
  • PI_Darwin_DTDS.pdf
Hello, could you answer me a quick question regarding Directype? When I run the 'Producer' it is creating the .TIFFs with a IBM PC format but I need it to be 'Mac'. Any suggestions.
Douglas
