A point of clarification.
Thank you gordo! This make things a little more clear.
I got a feeling that some people don't make difference between "real round dot" and "round-square" (euclidean).
BTW, maybe you can explain why the "real round dot era" started when ctp arrived? Was it possible to make "real round dot" in film based workflow?
However, it was problematic in a linear film workflow because the pincushion shapes resulting in the shadows would fill in and you would lose shadow detail. But that issue is eliminated in a CtP environment with the use of tone reproduction curves.
Again, thank you for full and competent answer. For me things became absolutely clear now.
One thing that i need to do next is to convince my bosses so that became clear for them too. I found a simple article from International Journal of Advanced Engineering Technology with next plots
I didn't make such plots for myself yet. Maybe you did with your creo team back in that years?
This is a good example of a poorly written technical paper and likely a poorly conducted test.
But if we won't take into account all of methodology errors and assumptions the graphs for 175 lpi are right, don't they?
For now company allows to make any tests for quite any purposes (and i really appreciate that)))))So do your own tests - perhaps use available space in the off cut area of jobs if you can't run a dedicated test.
I followed your advice (actually last friday, just hadn't enough time to measure samples)
So, input values:
RIP - Kodak Prinergy
Dot shapes:
1. EllipticalP
2. Round
1. Plates – 175 lpi, 2400 dpi, positive, linear (to exclude possible effect of compensation curve)
2. Paper type 1-2, 130 g/m2, silk
3. Aims for solids – previously determined values with lowest dE according to iso 12647-2 (2007 amd). Tolerance – 0.08 Dencity
4. Press – sheet-fed manRoland 904
5. Samples taken – about 1600 patches (result is smoothed in kodak colorflow)
Result:
1. Elliptical
2. Round
Not so big difference in nominal values, but on a live image is much more interesting – round dot image looks much more "natural" than elliptical one. Elliptical is very "red" in the skintone of this particular image.
Now, what do you think of the graphs published in the "technical" paper compared with your results?
