Dot splitting/pulling in 1 corner of the printed sheet (KBA Rapida)
Tomas
Hello everyone.
Guys, I need help, who has encountered:
I have a 6-color KBA Rapida. On the third section (Magenta), in one upper right corner of the sheet, the dot crushes or stretches (the spread increases more than in other areas of the sheet)
It looks like this:
At the same time, taking into account the density, it is clear that exactly one upper right corner is distorted.
It does not look like paper crushing, since the upper left corner is an absolutely reference point. It is visible on all large-format works of about 1000 * 700 mm
The machine is decently and regularly serviced.
The problem does not depend on the change of the printing blanket (new or worn-in).
Any ideas?
i have same encounter, hope experts will reply asap
Hello everyone.
It looks like this:
Any ideas?
i have same encounter. hope experts can give inputs or a detailed explanation
Hello everyone.
It looks like this:
Any ideas?
Do you have slur targets on your colour bars, if so, can you share a photo of those.
This is great! I will investigate further. There are no such patches yet - I put it from today, collect the information and write an answer with photos.
Microphotos were very helpful in explaining problem.
Dot distortion looks more like a ghost double than an actual slur (elongation).
It is directional, diagonal, but from top left to bottom right.
I would guess paper distortion (wavy edge) would be from lower left to upper right) as it fans out.
I assume the plate is dot structure is good?
Next time this happens just pull a single of the effected color.
If it goes away, its a double dot.
If it's always the same unit/color, it could be a bag cylinder gripper/pad or transfer?
ghost double
Yes, in the microscope I see not slippage but doubling - a pale imprint of the main stroke.
paper distortion
For now I exclude the waviness of the paper - the cardboard is thick and such doubling is only in one corner and not across the width at the top of the sheet
Yes, the prepress controls the dot size to the reference. There are no failures.
slur targets
I put control scales on the sheet to check for SLUR. And printed several combinations of units:
It turned out that the defect is clearly visible after the third unit. When the sheet is transferred through the skeleton from the third to the 4th unit. If I do not even print with the fourth unit, but the 5th or 6th, the defect remains. Apparently, the sheet changes its position in the grips of the sheet transfer section.
The closest solution is to clean the grips from dirt. Perhaps it is there.
What other options for solving the problem?
