Duplo DBM-120 error message
BigSi
Hi there. Just a silly little problem. See attached. I had to pull both the side covers off my old DBM-120.
Obviously I have now put back. I have turned on and off. Pull power cord out. I'm guessing there is a mico sensor somewhere?
Any thoughts much appreciated. thanks Simon
I believe there is a microswitch at the bottom left inside of the front (operator's side) cover. Maybe it's not fully depressed? See the attached page from the parts manual.
  • Pages from Duplo DBM120 Parts.pdf
thanks Stickman. I'll check it out. ta Simon
Also the big red emergency stop will cause a cover error. Also maybe you had 2 errors and 1 still is causing it to fail.
