Duplo dc 615
chrisio
Hi all.
We have got a duplo 615 and want to turn on the registration mark tracking, however in the menu although the option is there, it won't allow us to turn it on. In the manual it says its an option with the ccd which we have because the barcode tracking works, but I just can't work out how to turn on the reg mark tracking.
Does anybody know?
Cheers
Chris
Chris, i know this is a very old thread - but did you ever get this worked out, ive picked up a 2nd user 615 and having the same issue, barcode reading works fine, but i cant turn on the registration mark checking.
I am afraid not, we never did figure it out and traded it in soon after.
In the reg mark settings in the Duplo software, try setting both distances to 3mm. I was having trouble with this as well but when I entered 3mm (or higher) for each distance it turned on. Hope that helps!
i dont sadly have the software (the dongle wasnt with the machine) - or more i have the software but not the dongle needed to run it :) (was quoted over £700 for the dongle so im just uses the lcd panel for now)
BUT i have noticed that if i use sra3 size the option to select registration marks works, it seems it doesnt like it on non standard sizes - i use a lot of 225x320 (sra4) and it wont give me the option on that but does on the full SRA3 (not tried other size combinations)
