Cycle through with the <^> to count push green buttonThanks for the response. I tried holding the forward/backward buttons on start up and it shows me H00. I'm not sure what to do after that.
Just curious if you were able to find the counts. Duplo gives it an average lifespan of about 1 million sheets of 230 g paper since most people run heavier than that I usually go by 750,000 gives you a ballpark of when your cutter blade and/or slitter blades are getting towards the end of the life. The slitter blades have to be replaced because they get dull and get smaller so they don't rub against each other to make a cutting surface as for the cutter blade itself the motor that drives it wears out and the blade itself gets dull about the same timeCycle through with the <^> to count push green button
