epson 10600
Luis M
I was getting an error code 0.100 maintenance required, I reseted the counter with the right cover off because I was checking other stuff and it said ready, after I put the covers back on, now I have no display and the plotter comes on for 2 seconds I hear like a relay clicking and shuts down. HELP PLEASE
If the printer is shutting itself off after 2 seconds, I would check the manual and see if there is a way to reset it to factory defaults. You could call Epson support and ask if there is a way to reset it, or if they've heard of the problem where the printer shuts off after a couple seconds.
Just guessing from the symptoms at what could be causing it, but I'd say it could be a problem with the power supply/cable or a software problem. If it isn't, it could be that one of the main motors has died and it can no longer do a self check when it starts up. It could also be caused by failure of your low voltage or high voltage boards.
Also, check that the waste container is empty.
