Hi
We have a couple of Epson 9880s printers running well with sublimation inks.
we recently purchased 9700 as it is very fast.
Initially we got dark banding. with adjustment, we could remove that. but now we have thin white lines only on left side of the print.
checked nozzle, fine.
priner is running at 360x720 one direction. if we use bi direction, the white lines are across the print. (not 100% sure of this as did this only a couple of times, can check tomorrow)
in addition there are two deep thin white lines at the start of the print.
As we have used sublimation ink with refillable carts, dont expect epson help.
1. is it a paper feed issue? or head issue? or allignment? what else needs to be checked?
