EX-i 80 won’t pick up any IP at cold-start—only comes alive after “DHCP → BOOTP → DHCP” trick Versant 80
pablocobos
Hi all,
I’m struggling with an integrated Fiery EX-i 80 on a Versant 80 Press (System 10).
This is the behaviour I’m seeing every single morning:
  • Power-on sequence
    • Fiery boots, but the NIC never receives an IP—not even the static address I assigned (192.168.68.240).
    • On the RJ-45 jack only the upper green LED (link) is lit; the lower LED (speed) stays dark.
  • Work-around that revives it
    • From the Xerox front panel → Connectivity & Network Setup.
    • Change IP Address Resolution from DHCP to BOOTP, tap Save (Fiery restarts the interface).
    • Change straight back from BOOTP to DHCP and Save once more.
    • Fiery reboots; this time both LEDs light up (upper = green, lower = amber) and the server finally pulls a proper IP from DHCP (or honours the static one).
  • I do that little DHCP-BOOTP shuffle, the Fiery is invisible on the network.
it could be the NIC in your device, could also be a bad port/connection between the cabling and the switch its connected to. I'd try a brand new ethernet cable, hook it to a desktop switch and plug that switch into another network port. Try to completely rule out the cable/wall outlet/network port that it is currently plugged into.
