Green Printer
Registered Users
What is the thinnest ink film on the ink ball that the ITB can effectively transfer? For instance .2mil or .5mil or 1 mil.
Erik thank you for the further explanation.
The ITB concept has the ITB tip metering a consistent amount of ink on the ink fountain roller back to the ink fountain. The amount of ink that is metered back depends on how the tip is designed. The return ink could be equivalent to 0.001" or 0.004" or something else. The ink keys are then zeroed to this amount, what ever it is.
Ink that is metered onto the ink fountain by the ink keys in excess of this zeroed amount is collected at the tip and eventually is fed into the roller train.
The point of the ITB is that it transfers volumes of ink and not necessarily films, so it is hard to answer your question in precise film dimension terms.
There is variation in all things. There is variation in the feed rate of ink by the ink key onto the ink fountain roller. There will be variation of ink being returned by the ITB tip. But by far the largest source of variation in an offset press is the pick up of ink by the ductor because it is affected by so many variables, such as temperature, water press speed, etc.
You can argue the little points that have no major impact but what you really want is "No Change" in how things work. You will never be happy no matter how much is explained and I am not interested in trying to make you happy.
Erik . . .
Wouldn't the answer be 0? you could adjust the ITB tip to transfer no ink at their "Zero" setting and then if you increased it thickness it would start to transfer.
Also as a sidebar - if you have no interest in making your potential customers happy . . . I have found that frequently you have no customers![]()
Hello Erik,
IS a preset Zone/Key profile applied onto the Ink Duct Roller Face prior to ITB ???
Regards Alois
@Erik....I managed to view the video on my phone, But I could not understand the working principal of the ITB. In the video it looks a blade that is taking off ink from the fountain roller.
Can you explain the ductor roller, is it constantly in contact with the fountain roller or is it moving like normal ductor roller?
Where does that ink that is taken off by Blade goes?
Hi Erik!
After 2 hours of extensive reading of the patent link, now I got the basic Idea of your invention. I have a question in mind, The distance between the blade and fountain roller will be fixed or is it going to be operator adjustable?
So...lets say, if I am running a job with 50% fountain roller sweep and 30% ink zone opening, will this ITB will effect these settings too or not?
And what about changing the color on that unit, cleaning that ITB will be an issue too.
Revolutionizing Layout Planning and Automation InSoft Automation announces the launch of Imp Version 14, the latest iteration of its industry-leading cost-based layout planning software. Packed with cutting-edge features, this release redefines efficiency, automation, and workflow optimization for printing and finishing processes. Learn more……. |
