False disk was not ejected error
couriergraphics
Keep getting the error"the disk was not ejected properly. If possible, always eject a disk before unplugging it or turning it off." Very Annoying see attached. And no there was not a disk removed improperly.
Intel Core Duo Imac10,1
3.06 Gh
L2 Cache: 3 MB
Memory: 4 GB
Bus Speed: 1.07 GHz
Boot ROM Version: IM101.00CC.B00
SMC Version (system): 1.52f9
Serial Number (system): QP0191EZ5PC
Hardware UUID: A33B195C-EC74-58BF-BBCD-1E9BC5B9A5F1
System Version: Mac OS X 10.6.4 (10F569)
Kernel Version: Darwin 10.4.0
Boot Volume: CG8
Boot Mode: Normal
Computer Name: CG8’s iMac
User Name: CG7 (marklewinger)
Secure Virtual Memory: Not Enabled
64-bit Kernel and Extensions: No
Time since boot: 22:27
Not that it helps you much but, this question probably best belongs in the Information Technology->Windows Help Desk topic...
That being said, it sounds like perhaps a USB thumb drive or SD card was pulled from its connection rather than being ejected. Another option would be a network drive that looses connection - might happen if the network interface card powers down or you loose network connectivity.
Mark H
Do you have any kind of external drives attached? I've seen this on my Mac with a USB external drive attached and if the cable gets moved in a certain way this message will pop up even if the drive doesn't actually dismount.
