File Size
Re: File Size
are you talking about attaching a PDF to a post? if so, 100K is the max file size for a single attachement
Re: File Size
Yes, trying to attach to a post. File is 1.1 MB and there's no way I can get it down that small.
Re: File Size
Unless you need for someone to try to work on your PDF itself you can maybe
take a screenshot of it and save as a GIF file which might crank the visual down
to under 100k for viewing purposes. Otherwise - working a PDF that can only be
100k or less is probably not feasible.
It may be that some in here can look at the PDF itself and offer a suggestion or two by
just seeing it.
Worth a shot to mention.
Re: File Size
We received a PDF with a color problem and I was wondering if anyone could tell me what the customer did wrong. I can't figure it out. But, I would have to leave the PDF as is to do so.
