flexographic photopolymer plate help please
Dujo
Hello everybody!
Sorry if this is not the correct category to post this
We need all advise how you can help us as we are absolutely beginner in
flexographic photopolymer plate making.
Our printshop The Keskeny and Co. Print Ltd. ( Keskeny és Társai Nyomdaipari Kft. )
is one of the largest sheetfed offset plant in Hungary. We are running
with Heidelberg presses with coaters inline for aqueos and UV coat .(
Chamber doctor blade system with different raster rollers).
The formats are B/1 , B/2 , B/3 how we can varnish, maximum size is 1048x800 mm.
We plant to make the flexographic photopolymer plates in house by the
most economical way. Currently we own a Bacher 3086 typ. lighting box
with an MH 5KW lamp inside.
We used to copy the conventional offset plate in it. It would be great to copy the polyester based plates too with this equipment (but of course with some modifications, lamp, ect). Then wash off with water.
What do you think on this process ? Can it be a viable solution ? What
are the advantages and the disadvantages of our plan ?
Quality wise , size wise , metall backed or polyester back ???
Quality wise we need fine line works for varnishing and accurate register!
Which system can be perfect for us ? The Dupont Cyrell , Flint nyloflex
, Toray , Asahi ....
We are ready to listen to all advises within this process and learn the
best , flexible and most econimical way to make photopolymer varnishing
plates.
Hi Dujo
Just found you on Twitter, not sure how much help I can provide with your description of your equipment but can certainly help you with plates. Visit my company website Repro . We supply plates to Poland and Portugal economically so maybe we can help? Feel free to contact me if you're interested or even if you want to expand on your issues mentioned above.
Craig
MPH Flexo
Ex parker service engineer
Hi Dujo
My name is Denis and i offer Free Advice, spares, repais and Lamps on all uv equipment.
The uv output of the lamp needs to match the uv response of the materials being used.
I can be contacted by email: [email protected]
or by phone on 07872 632155 and i am based in the UK.
Regards Denis.
