Have done several runs of a flood back business card. The client must be noticing rub when keeping them in a wallet as they are now requesting Dull Aqueous flood over the back.
Do they really think small offset printers have Dull Aqueous capability?
After several long deep sighs I mentally conceded that I should do something; Flood gloss varnish or UV. Because it is a frequent run and not simple I pre-printed this backer 3 weeks ago.
I put several sheets through our Tec Lighting UV Coater with high hopes; I rubbed two sheets together with moderate pressure and transferred backer ink to the clean front; another sigh...
I don't have any varnish, a bit of a surprise. I used it semi-frequently several years ago (when printing was a day to day occurrence).
I expect a 2% chance of myself applying an Aqueous overprint.
Can a Ryobi 3302 apply Aqueous???
Would it be more effective than UV coating on an uncoated sheet?
Would varnish be more effective than UV?
Ryobi 3302 - 200 sheet run - 8 up bleeding BCD - Flood Pantone 433 with open reverse type - Cougar 100# cover
