FullSwitch & FlightCheck collect job
Hi All,
Anyone know if it is possible for FullSwitch to use FlightChecks collect job function? as far as i can see it only gives access to the ground controls.
Sorry, looked at the flow I had designed with it. I had used FC as a gateway to use MadeToPrint to collect the jobs, not FlightCheck itself.
Automating the font and image Packaging with FlightCheck
Hi All,
Hi, yes, that should be possible with FlightCheck Professional and SWITCH, as FCPro is Apple scriptable and I know in the past users were doing this. Here is a two part video that shows you the basics and more on how FlightCheck can work with SWITCH flows:
YouTube - Automating FlightCheck with SWITCH (Part 1 of 2)
And here is a check images flow for Enfocus FullSWITCH:
Enfocus - Check images with FlightCheck
And for automating preflighting:
Enfocus - Create and preflight with FlightCheck (GWG)
You can get the latest desktop version of FlightCheck here:
Preflight Adobe InDesign, QuarkXPress and more with FlightCheck!
-David
Markzware
Yes, FlightCheck is scriptable but FullSWITCH cannot use scripts; only PowerSWITCH can.
Who's your SWITCH reseller? Didn't they tell you that you can't do that?
-David
Markzware
Thanks David, is this the only way to get a response from Markzware, tried support and various other routes and still no response.
