kewlbigdan
G-Seven Calc v2.1
by KewlBigDan
THIS SYSTEM IS NOT CERTIFIED BY IDEALLIANCE and will never be. Seriously $7000??
This Excel Document is FREE. You must of course own the Excel (2007/2010) application. I am not sure it works on MACs, other Excel versions or other Excel document emulators.
I have used this software 100's of times for RIP curve calculations, verification, and G7 certifications and it gets us through each time with no problems.
I have to say it is not a polished system, and you have to have your data in a certain format for it to work but if you follow the instructions it should get you very close to where you want to be without spending $2000 for a professional app. Saying that, Purchasing any of the G7 Certified Systems would always be better if you want guaranteed results, but if your on a budget, or work for a cheap company and your tired of Fangraphs...this will work.
The 1 MACRO only imports (copy paste) the data from another excel file (your saved P2P25 data) so if you want to manually do that disable them, it still calculates fine.
My company put me in charge of getting us re-certified G7 Master Printer and I had no clue what G7 entailed. they also didnt want to purchase the Curve2 software and wanted me to just use the Fangraph method for 10 presses, 5 substrates, and mulitple runs. So rather than sit for 4 weeks manually calculating fangraphs for 150 P2P25s, (ok dont roll your eyes, I said I didnt know what I was doing, was just following orders).
So I searched on internet for another solution. There didnt seem to be any application other than the $2000+ applications out there. So I started reading, searching, experimenting. I started in Filemaker Pro, but decided to move to Excel as it works for all the calculations.
I got my hands on the G7 How To 2008.pdf which unlike the G7 How To 2009, Has most of the formulas required to get the results. This problem came translating these formulas into something workable in Excel. As the Formulas deal mostly with LAB, it took another month of searching mathimatical conversion formulas to be able to convrt Densities into *L and back again, and working out the correct NPDC curve data.
First I worked on the brute force method of just inputing the values from the Fangraph and doing a look-up, lots of data entry but after useing this method for testing I stumbled across how to do all the math to dynamically (learning polynomial equations in the process) calculate the curve for any SID. This was a boon as it opened up alot of other factors that then became possible.
So by this stage I could target teh NPDC curve dead on with a simple Correcttred RIP curve but the Grayscale *a *b formulas still evaded me.
So embedded in all the calculations are 5 different calculations by radio button for calculating the Grayscale. I tested each extensively but none really worked correctly. Maybe I was blind or dumb but I could not figure how to have excel find the Gray target off the P2P25 and then calculate the desired grayscale RIP curves.
6 months went by, I gave up. Then one day I was reading some obscure manuscript from a professor to his students about something and it all clicked. (The paper had nothing to do with G7 and was dated in the 70's if I recall, why I was reading it I have no idea, it was one of those moments when i typed some weird thing in the search engine and it popped up). Anyways, I rewrote, which I hate to do, hence the still embedded 5 grayscale calculations, the grayscale calculations with this new understanding and the results were spot on.
Since I wasn't G7 anything by this stage, I still had to use a G7 Expert company to verify and submit all our G7 Master Printer data and I submitted our data for analysts and the results from their Curve2 software matched exactly my results, down to the graphs depictions.
by KewlBigDan
