The last one I knew of that was close was Lustro (LOE), but that is no longer being manufactured. There are a few that are on the outer edge, depending on which spectro is used to measure them (Sterling, Opus, Utopia)
Bret
Just be aware of the OBA (Optical Brightening Agents) content of the papers that you are considering since they can effect how your instruments read/misread your calibration forms.
best, gordon p
Gordo,
Do you have any tips on how to locate the right substrate?
My thoughts were to use the stock we use most often as our house stock.
I'm not getting much help from paper merchants, they act like this is the first they have heard of G7. Do you know of any sources that can help me out?
Just a point of clarification, G7 is a method not a specification.
Paper mills and merchants use very different methods and metrics compared with what printers use. That being said, it's disappointing, given the interest and uptake of GRACoL 7/ISO 12647-2 that your paper supplier (probably like most paper suppliers) has not identified specific papers in their inventory that conform to the ISO specification.
I'm sure there are better ways, but in your case, I would ask for your paper supplier's swatch books so that you can measure the color of the paper yourself. For commercial printing your looking for a type 1 paper with as little fluorescence as possible and a nominal white point of 95 L* (+/- 3), 0 a* (+/- 2), -2 b* (+/- 2) (measured with non-fluorescing white backing).
You can get a qualitative idea of the amount of OBAs in the paper by viewing the samples under a cheap black light like this:![]()
available for less than $10 at any shop that sell rock n' roll paraphernalia. You want the one that uses a fluorescent tube rather than an incandescent bulb.
While you're doing that, check the OBAs of your proofing paper relative to your press paper:
You're looking for a proofing paper that has similar OBA content with your press sheet.
hope this helps, gordon p
Very clever. Thanks Gordo!
Productolith Gloss Lab measurements are acceptable(pass) for G7(ISO).
Regards,
Todd
You can get a qualitative idea of the amount of OBAs in the paper by viewing the samples under a cheap black light...
gordo p
What are your thoughts on using proofing mediums with/without optical brighteners given that virtually all press stock has varying amounts of brighteners?
I recently moved to a new Epson proofer with integrated spectrophotometer and an OBA free premium proofing paper. I am extremely happy with it but I just can't shake this lingering thought in my head that OBA free proofs vs OBA press sheets is not any better than inconsistent OBA proofs and inconsistent OBA press sheets.
We are using EFI 2200 gloss proofing paper which falls in the LAB spec of the G7 "METHOD" (thanks for that clarification also).
Revolutionizing Layout Planning and Automation InSoft Automation announces the launch of Imp Version 14, the latest iteration of its industry-leading cost-based layout planning software. Packed with cutting-edge features, this release redefines efficiency, automation, and workflow optimization for printing and finishing processes. Learn more……. |
