I am running a Presstek 34 DI machine (4 colour) printing gang run business cards, postcards etc. Up until a few months ago I was printing a flood varnish, but I then switched to running an ink train AQ gloss coating. It has worked great and the drying time is much better than the varnish.
I recently switched from running a 12PT gloss cover to a 14PT gloss cover...same brand of stock, just thicker. On the last couple of jobs I have run, we have been getting gas ghosting on the first side of the AQ that we print. The gloss of the AQ is less wherever there is heavy ink coverage on the reverse side of the sheet. If there is light coverage on the back then the gloss is high. We are not ghosting in the printing of CMYK, only ghosting on the AQ first side. We back up the AQ pretty much right away and we do not ghost on the second side I assume because the front side AQ seals everything.
I have tried reducing the IR or turning off completely (usually I run low IR on first side and then turn off on 2nd side). I printed the AQ on a job that sat for about 24 hours as well as one that sat only for about 4 hours and the results were pretty much the same. Turning the IR completely off helped a bit but it is still there a bit.
Any ideas? So far things maybe are pointing to the change of paper as I can not see what else would do it. I do not usually run the press much anymore as I have a new pressman. He seems to keep his delivery pile quite tight and the sheets seem to deliver hard. Could this be slowing ink drying and trapping escaping ink gases?
