Erik quote
"In a real world demonstration, when you properly feed the ink into a press in a positive and consistent way, density is very consistent and changes in water, temperature or press speed will not substantially affect density. You can not wash out the density no matter how much you increase the dampening."
Does a Goss Digirail every washout?
Green Printer,
This is a great question and is a good example of the subtle issues of positive ink feed.
To start, I will comment in more detail what positive ink feed will do.
Consistent positive ink feed will ensure that "the average steady state density" is going to be very consistent.
The variation in the average will be related to the variation of output of the positive ink feed system itself. This means that if you require the average density to be within a tolerance of +/- 0.05 pts then you need an ink feed system capable of doing that. If you want the average density to be +/- 0.02 then you have to design the positive ink feed system accordingly. It is a performance target that can be designed into the system.
Now please understand that I am talking about average density. One can have variations about the average and variations about the average density are due to press design issues. Some are small and quick variations due to uneven inking of the plate by the form rollers or some can be larger and long lasting which are related to how ink is stored on the rollers of the roller train. This is also related to how fast the press will respond to a density change.
So ideally a press should have a positive ink feed to ensure that the average density is consistent and properly designed roller train to ensure that the inking of the image is consistent in all locations and that the response time is short when making a density change.
Now we can look at the Digirail concept. It has what they call a rail, which is a beam adjacent to the ink fountain roller and where ink is metered out from the rail to the ink fountain roller in zones. These are basically similar to the ink key zones. The Digirail is claimed to be extremely accurate in feeding ink. I have no reason to doubt that claim so lets just say it perfectly meters ink.
The ink goes on the ink fountain roller and moves around to the pickup point. On these faster presses, they normally do not have a conventional ductor roller but tend to have a continuous ductor. This is a knurled or patterned roller that is set about 0.004" to 0.006" from the ink fountain roller. As the ink comes around, some of it gets sheared off the ink fountain roller by the continuous ductor and it then goes into the press roller train. I consider this point as the start of the press roller train.
The Digirail is a positive ink feed device and we have said that we will consider it to be a perfect metering device of ink. So I would expect that the average density for a press with this device would be very very consistent. No drifting of average.
So now to your question about whether it would wash out. I have to say I don't know for sure because it depends. Let me explain.
The problem is with the continuous ductor. The continuous ductor is an inconsistent ink transfer device. (My ITB corrects this problem.) Since the continuous ductor will have variations in ink transfer from the ink fountain roller to the press rollers due to changes in temperature, water, press speed, etc. this means that these kinds of disturbances will vary the rate of ink going into the roller train.
Since the Digirail is a positive ink feed device, these disturbances will have only a temporary affect on the ink transfer from the ink fountain roller to the roller train.
It happens this way. Say you are running at an nice steady rate with consistent density. Now make an increase in the water setting. This increase in water gets into the ink on the roller train and will affect the ink being transferred into the roller train at the continuous ductor. So you have a constant ink feed onto the ink fountain roller train but a drop in ink transfer to the roller train at the continuous ductor.
What happens. Less ink going into the press will show up as a drop in density because eventually the ink being printed out must be equal to the ink going into the roller train at the ductor. But while this is happening, the ink is building up on the ink fountain roller to a point where this increase in ink on the ink fountain roller starts to increase the ink transfer at the continuous ductor. This then starts to increase the ink on the roller train and the density starts to be restored to its previous steady state values.
The reverse will happen when you decrease the water. The length of time and the amount of variation will depend on how much the ink storage levels of the ink fountain roller and the roller train have been changed. This is related to some press design details.
So if one increased the water greatly on a press with a Digirail, would it wash out? It might but it would only be for a short time since the ink feed into the roller train would recover. I would expect some variation in the density even if it is not to the point that it would be considered as being washed out. But the affect is temporary. One other thing I am not sure of is if there are continuous disturbances, would that result in continuous minor variations of density about the average?
Now the other problem with the Digirail is with the way it is normally configured. It has a very long response time to density changes. This is due to the inking of the ink fountain roller and the use of the continuous ductor. To get to a steady state condition, the ink film on the ink fountain roller has to increase to the point where the ink transfer at the ductor comes to steady state conditions. This can take a very long time and that means a lot of printed paper. That is one reason why use of the Digirail can be a problem for commercial printers who want to get to colour very quickly.
Now the funny thing is, my ITB corrects this problem that the Digirail has with slow response and the sensitivity to disturbances of water, temperature and press speed. A simple version of the ITB, which would be a simple scrapper and pickup roller, would make the ink transfer consistent and independent of changes in water, temperature and press speed. The response time would be greatly improved because as soon as the Digirail changes its output, it would go directly into the roller train instead of having to increase the total ink film on the ink fountain roller first.
The Digirail is very accurate but that is not why it performs better than conventional open ink fountains. It is because it is a positive ink feed device. Right now, the accuracy is wasted due to the inconsistent ink transfer of the continuous ductor which can allow large scale temporary variations in density. If you have a consistent average density but large variations, you still have a problem as a printer.
High accuracy of ink feed is nice to have but it is not at all required. To hit a tolerance of +/- 0.05 density points is about +/- 8% ink volume. Not a tight target at all.
I hope you were able to follow the logic. I do have some practical experience with this. In the early 1990's I developed an experimental pumping ink fountain for UV inks. Ran it on press in production. I applied the ink directly onto the ink fountain roller and it took a while for me to understand why it was so slow to respond. I commented on this response problem and the proposed theoretical solution in my 1997 TAGA paper.
