In our bid to eradicate alcohol from the pressroom we have tested a range of fountain solutions.
Some have contained in concentrate 1% - 3% glycols others 5% - 10% glycols others 45% - 70% glycols.
Using the same ink set what we have noticed is that the higher the glycol level in the fountain solution worked out via the concentrate level then the mixed fountain solution glycol level. There becomes an issue with drying, scuffing & rub resistance.
It seems on polyester plates running alcohol free with standard ink sets need a certain % of glycols to effectively clean the plate and keep it running clean. It's a shame low level glycol founts don't work with standard inks as the jobs dry significantly faster.
Is there anyone out there that has worked out the approximate % level of glycols that can be in the mixed fountain solution before there is a detrimental effect on drying, scuffing & rub resistance?
