gripper change in pdf file..
  • Thread starter Thread starter kala
  • Start date Start date
K
kala
Guest
Hi
Which is the easiest way to change the customer set pdf with gripper ...
For eg customer gave the imposed file with 50mm gripper from cut mark.. we need to change that into 60mm
we will place the pdf (20 forms) each manually (20 times) in third party software/ illustrator and move the gripper as required then output for plate...
we tried with preps but measuring from cutmark and alignment position takes more time any advise from experts pls...
regards
Kala
Why don't you just increase the Gripper Margin on the CTP by 10mm.
That way you don't need to open edit or re-save the PDF file.
I think you may be looking for a complicated way of doing something very simple.
I agree that changing the setback in the imagesetter for a certain plate sounds like a great idea. I would try that first.
