Guide to Buying New Digital Equipment
rcreveli
I am not a purchasing expert of any sort but, I feel over the last 15 years I've been involved in a lot of equipment purchases, digital, offset, bindery etc. I feel that we've developed a system that is easily adaptable to any one in the industry. Since this is the digital forum I'll use that as an example.
1. Wishlist/Criteria
If you are replacing a piece of equipment this will be easier than buying something completely new but now is the time to make and rate you list.
Here are a few of our criteria - we ended up with 17 for our new digital press
1. Improved Image quality - we defined this to mean closer to offset than our bizhub 6500 with improved grayscale and better spot color matching.
2. Must be able to run 13x19 out of 1 drawer
3. Duplex 300 GSM
4. Improved deskewing
5. better color controls
etc.
2.rate your critera
Assign them value from 1 down. In our case #1 was improvement in quality. #17 was inline finishing because of our offline capabilities. Also Inline finishing is quite expensive and Inline stitcher can easily go for between 20-40K US$. That's a nice upgrade to your offline/nearline capabilities.
3. Find Machines that fit into your criteria. Your top 5 criteria are going to help you eliminate machines very quickly. Our #2 Criteria of duplexing 300GSM with our #1 of improving image quality got us down to 3 machines from 5 vendors. 3 Vendors proposed to Bizhub 8000.
4. Test 1.
We gave each company the files with offset printed samples and a carton of paper. They were told to match there output as closely as possible to the offset. We specified which controller and then let them have at it.
5. Double Blind Review
I've been doing this for 15 years. I and everyone I work with have some bias regarding vendors. Maybe we didn't like a tech or had really great experience with a machine. I sought to eliminate this from the first round reviews.
I took all of the outputs and assigned them a number. I then gave key employees a questionnaire and asked them to review the outputs. These employees including the production manager, the designer, the digital key op and the owner.
The questionnaire had both objective and subjective questions for each of the 3 sample files ie.
Which output most closely matches offset
Which output looks the best.
I then tallied the results and we were down to two machines.
6. Stress Test.
I went to see the vendors and brought a carton of 100# coated cover and a test file that I built. This file was brutal It has multiple different skin tones, RGB B&W images. Both blacks and whites with fine details and solid swatches. I then printed the file head to tail to check that the entire image are was consistent.
I ran an entire carton at each site. I timed the job and pulled and marked regular samples for consistency.
7. Haggling.
Ask for the world.
Go back a re asses ask about component prices. We saved several thousand dollars by getting a finisher with a staple unit instead a just a stacker.
Remember that most of your bill is going to be clicks.
So that's the system we used for both our last major purchases. The interesting this about this system is that both times the winner was not whom we expected.
When we bought our last B&W generation we bought Xerox 4112's a machine we had no interest in
This time we decided on a Canon solution. This was even more surprising since both the owner and I haven't looked at Canon color since the CLC 1000/5000 generations we were so badly burned.
Sorry for the long post and I hope this helps some of you.
Great System !
Great System !
I like your testing system!
Did you choose the Canon 6000/7000 or the 6010/7010?
Also did your testing include the Xerox 800? The Fuji guys were pushing it.
If I understood correctly the Bizhub 8000 was #3 - what was machine #2?
Erth
We chose the the Canon 6010. It best met our needs at the price we wanted. we would have liked the VP but the CPM is not a huge issue for us and this machine gives a a significant speed boost over our 6500. Also the VP requires 3 phase which would require additional expense in instalation
The 800 was considered briefly but was way out of our budget, had a higher click rate over 11x17 and we did not think we could sell it's advantages to our customers.
Our top 3 machines were
the Xerox 7002 - eliminated almost immediately due to concerns from other printers
the Xerox 700 - eliminated for quality in the double blind and stock handling
the Bizhub 7000 - eliminated during the double blind
The bizhub 8000 - first runner up
The Canon 6010
Canon 6010
Canon 6010
How is it going so far with the Canon? were just about to sign for the 6010vp with the oce rip to replace our Xerox 5000
Cheers
Ron
Canon 6010 follow up
rcreveli
You have had the Canon 6010 for about 4 months now - can you me a review.
We have talked with the Canon rep and have been quoted $105,000 for the 6010 with the A2200 server, the AJ2 two bin saddle stitcher and the POD Deck A1, installation,set up training and a .055 color click and .02 b/w. The the same setup with the 6010VP was $138,000.
In reading some of the other posts wmwilker has ongoing problems with the 7010VP.
theBluesDude did you get 6010?
Erth
Thanks for sharing this informative post. This post will really helpful. Digital equipment are very sensitive and very costly. They provide high class efficiency.
___________________________
t1285 compatible ink
rcreveli
Erth
Hi Erth, no we didnt get it in the end, they messed us about big time and changed the price four times, even though it was getting cheaper everytime it still had a glaring error...no engineers within a hundred mile radius to us. The good thing for us short term was that Xerox gave us another DC5000AP as a sweetener to stay :O)
The Canon product is a great machine. To say your having problems might be caused by a variety of issues. if the machine was set up properly and your running between 50k and 200k (any size) there shouldn't be an issues. get the reseller to have Canon out to check the machine out. they run like champs....
Nice post rcreveli! I feel that this can defiantly help people when they need to buy a new digital printer and just aren’t sure where to start. Could you possibly show us what the stress test looks like that you used? I think it’s a wonderful idea and I’d love to see it!
Hi there,
U can go for Ricoh Pro C751 EX where u can add Multibypass tray also which u can Print 13" x24.8" (Its a Optionel) rest all features are there in this Particular Machine. About the quality of the Prints its a 4800 DPI Mid range color Digital Press. Basic Config of this machine with 13x19 LCT tray and Stepler Finisher.
Regards
Anselm
RC, when you gave your case of paper to your different vendors to try to match press color did you stay and watch them do it as to make sure they were producing it on the machine that you were interested in and not some higher end model for better color. I like your post and criteria on purchasing a machine. There were a couple of things you listed that we will now incorporate into our purchasing process. Thanks!
