Halm jet chemistry advice with poly plates
mgk_print
I recently took over a Halm jet envelope press and would like advice on what water mix works best. I have some universal pink fount sol, IPA and tap water. The chiller is obviously not working either, so room temp (75 deg). Thanks
Green Printer
Registered Users
WDP has been used in commercial shops for over 25 years on plastic plates.
For Metal plates Gensis Think SF used in commercial printing for over 30 years.
