Steve_S
We are running into some issues with bloated processing times on a very large and complex VDP run we do monthly. I am not sure if we can improve this on the hardware side, like with a MacPro that is pretty built up, or if the whole process is just set up to be on the slow side. I'll try to highlight what we do:
Does anyone out there run anything similar to this? And if so, any suggestions you have for improving the processing time?
No solicitations for software please.
Thanks!
- Mac specs - 2.6GHz Intel Core i5, 16GB RAM, 500GB SSD drive
- In Design CC2015 with SmartStream Designer, using PPML to generate imposed PDF's
- INDD file has 300+ custom image and text variable layers depending on unique client totals each month
- Database is generally 85k - 100k per run, and we batch out in 1000 increments to PDF
- Currently, processing time to generate PDF's is 48-72 hours each run if we get no timeouts or errors
Thanks!
