New to the forum and I found it informing. I hope some one can help.
I'm running a SM102 CD 4+L and getting a double image between the second and third units. When running units 1&2 every thing is ok and 3&4 by their self are ok. When running all 4 units there is a double image. I'm new to the CD format and not sure on the gripper settings. I had a talk with Heidelberg and thing it is the 3rd unit Imp. cylinder. I put a dial gauge on it and can not get any movment on it. I've checked over the transfere grippers with a feeler gauge and found some lose ones. As for the Imp. cylinder I'm unsure how to adjust them. I went under the press and checked them and found a few bitting heavy and a .001 differents between the two. The only job that was ready to run tonight fell out so I can't check it. Hoping to get some help. Thanks Olie
