HighWater Python
valkire
I need some help for installing Python software. Installer need two Windows users: one is "engineer" with administrator privileges and second is "python", but I don't know settings for "python" user. So, I kindly ask HighWater Python users to check this user setting.
Set it as administrator also. Normally it is set as power user but occasionally that causes issues.
I try with Administrator and with Power User but I still have same problem.
"One of more of the following User profiles required for this installation is missing or invalid:
python
Please correct the problem before trying this installation again."
Do you have Python? Can you check user group, description and full name for python user? I don't know does installer check this informations.
Thanks in advance.
Did you create the hard drive partitions? Also try creating users with the names: QA, Soak, and Ctpnet give them the same rights as above.
Sorry for late with answer. I create QA, Siak and Stpnet users, but same error.
Here are pictures of user and and dis managemet windows.
I tryed to change drive letter for partition E to D but there is an error message: "Cannot modify the drive letter of your system or boot volume."
You might want to contact Marlowe in the UK. They are the company that provides service and support on the Python.
Marlowe
