Bojan_Libra
How to create CIP3 in Prinergy Evo ?
You must have the Printlink license for the output format that you need.
If you have the license, then you can check the printlink operation in a output template for generate the PPF/CIP3. This option probably is more expensive but it is more integrated in the workflow.
If you haven´t the license there are systems that they can generate CIP3 from the information of the VPS files.
Regards,
Nacho
InkReady, made in Canada, will output a CIP3 PPF and a printed report to set keys/fountains. Our solution for Windows also has hot folders to automate, dot gain correction and more. At only $1495, it pays for itself in no time.
Complete evaluation version is available for FREE. (time limited license)
Ray Duval
raymond @ imposition.com
Ultimate Technographics
Ray Duval
Correct, for older presses, InkReady prints a detailed report with a complete details to do the make ready. No needs to configure complex software, cables, cards, etc.
Yes but that´s just ink coverage information. This information (according to our experience) should be optimized for a press which ink fountains are to be preset as well as paper and ink so that it would help printers presetting as accurate as possible. A press interface allows printers almost an automatic ink preset which significantly saves makeready time.
Bran
The test to see if a presetting system works well would be to start the press and see if it can go to the density target ranges without the operator or a closed loop control system make any ink adjustments . If the system is not able to do that, it is not capable and the people who designed the system do not understand the problem.
In my experience, the methods used in ink key presetting systems are based on the same principle used intuitively by press operators. I.e. eyeball the ink coverage in each ink zone and estimate the amount the keys need to be opened in order to deliver the needed amount of ink.
In that context ink key presetting systems are much faster and more accurate than the press operator. Some solutions can also "learn" by comparing what was predicted vs what was actually needed and modifying the algorithms accordingly.
And in that sense it is capable and it doesn't matter if the people who designed the system understand the problem or not.
The system may not be optimal, but it appears to be sufficiently better than eyeballing the plate. At least until a better method is developed.
best, gordo
The solution to the presetting of ink keys is not directly related to the image coverage area, so even if the computer accurately calculates the image area instead of the eyeball approach, it only means that the calculation is a more precise calculation of the wrong data.
I am a little surprised at your satisfaction in aiming low. The calculation for ink key presetting does not requires high precision but it does need to be accurate.
I would guess that the engineers at Creo that you knew, would not be happy or satisfied if they thought an algorithm was not good enough. Users of an improved technology might not think that is an issue but for those who design the technology, knowing that it could be better will bother them. It is the knowing that it could have been better that will drive a designer crazy. It can be viewed as a lost opportunity instead of the success that the market might see it.
