How to open damaged pdf file?
ErickHorn
There is pdf the file and it is known that somewhere in the middle some bytes were changed. Adobe Acrobat Reader can't open it. Is it possible via something still to view this file? Whether GSview will be able?
Since we're throwing out misc software . . how about Illy???? Dov . . . I know your not supposed to . . . but what r u going to do????
It is necessary to try! It makes sense to try all the available versions of Reader and Acrobat. Besides, certainly, GhostView. Also Fotoshop (also you need to try all possible versions). The same method with other programs: Illustrator, Corel and so on... It is likely that any version will work.
Maybe you will find useful information here also)
Try placing it in Illustrator and either embedding it or saving it as an Illustrator PDF and then opening it in Acrobat.
