If you have a ctp inside you must have the temperature and humidity that the CTP manufacture need. If not is normal have the normal temperature 20 C and 50/60% humidity.
Thank you, in my printing shop i do not have ceiling, so when the weather is too hot, i think i am in a oven, how can i fix it, with out spending too much.
We have a Tcs gallus 250mm reel to reel offset(label printer) our summers gets
to 35 degrees c and its dry heat. Our water % we run at 48-55% at time the we have
a lot more variables, colour var.Our m/c specs says ideal temp is 21 degrees c. advise please
