I am just about to have 50 copies of book printed using an iGen. Sheet size is 520 x 280, and the print run will be about 10,000 sheets. The file will be given to the printer in PDF format, already imposed, ready to print. Nothing will need to be done to the file. Nothing. It's as if I took the file to a local photocopy shop and said "Print". If it comes out wrong, there's no one to blame but me. I'm paying for the proofs up front, and by doing it this way I expect to get a pretty good deal.
In 2006 I had test prints run off, before I started laying out the book, to make sure that the iGen (and NexPress and Indigo) were of suitable quality. The iGen came out on top. My comments from the iGen tests will be posted as a reply.
I had a first proof run off in December 2008, but an hour or so before printing the printer rang me to say the price had doubled, through no fault of mine. He agreed to print the proof, which I would pay for, and then I was free to seek new quotes, including from him.
So I have a book now, but no printer. I have recently approached a few printers for indicative costs and asked them some detailed questions before I make a decision who to go with. I was disappointed at the lack of knowledge/conflicting answers, and so I thought I might pose my questions here to get some definitive answers. These are some of the questions I posed to the printers:
QUES 1
I wanted to know the print settings used on the first-proof, so that come second-proof and final-print, the settings could be reproduced exactly. I asked: was it possible at the end of the printing to save the print settings. The answers I received were split 50/50. Some said they could, some said they could not. The most knowledgeable sounding said: "I will make a Q with all the write settings attached to it."
So, can an iGen operator save print settings and, say, email them to a customer as a backup, so that next time the customer comes along with a repeat print, the settings are identical?
QUES 2
Some of the impressions for my book have colour (by impressions I mean one side of a sheet), some are true grayscale. The book is contained within one single PDF file. They will be no question of CMYK appearing on pages where there should be none. I will be thoroughly checking for colour on every page using Acrobat before it is sent to the printer.
I asked the question: "Will the IGen accurately report on the total number of colour impressions and grayscale impressions, or will I be billed as if every impression was colour. These are some of the answers I received:
Two other responses contradicted the above and said the iGen does keep track of colour/grayscale.
So, as a customer, should I expect a printer to offer me a price that reflects the actual number of colour impressions, and the actual number of grayscale impressions? Printer 1 is suggesting I have to pay the colour rate for all impressions, even though most are grayscale.
QUES 3
I asked about colour profiles. All my images have embedded profiles, but every one of the printers said they would ignore profiles. That surprised me, but I'm quite happy about not using profiles. The December 2008 proof, printed on Direct setting, was almost identical to what I see on my iMac screen. A surprisingly close match. I'm very impressed with the quality of the iGen and with the correlation between screen and print.
The first proof had a number of RGB images which I had not bothered to convert to CMYK. The printer said that was okay. The grayscale images would go through one stream, CMYK through another, and RGB through another.
My question is: when the RGB images are converted to CMYK by the iGen, what source and destination colour spaces are used? My images had been stripped of their embedded profiles, so the iGen must have assumed a source profile. What profile? sRGB?
If I want to convert the RGB images to CMYK myself, what destination colour space should I select? I want to mimic what the iGen does when it converts RGB to CMYK. Or is the destination profile a proprietory iGen profile that is not available to the public?
QUES 4
Do images that have resolutions higher than 300 ppi (say 600, 1200) have to be downsampled to 300 ppi? Do higher resolutions cause problems, or do they just slow down the ripping? I'd rather not downsample my images if it is not necessary to do so, given that the iGen effectively resamples anyway.
FINAL NOTE
I would appreciate any comments on the results of my tests (see reply to this post).
QUES 1
QUES 2
1. "I am sorry to say, but when we print a particular set in color, the whole file is sent in color mode... If we try to separate pages, we will have to break the file in pieces and that can be a very lengthy process and is not recommended."
2. "The iGen does not report this information. However, in setting up the print run we can ascertain the number of B&W pages and colour pages and the total printed for each."
3. "The IGEN does not specify which pages are colour and which are B&W"
QUES 3
QUES 4
FINAL NOTE
