chevalier
I recently made the switch to CS6 now that Esko plugins are compatible. My coworker (identical workstation) is also experiencing this issue.
The issue(s)
When going to print (file>print or apple+P) the "Print" dialog appears but quickly disappears like it has detected a return. It just prints out default settings to the default printer instantly. It's almost like it is registering a phantom return or something. Go to repeat this process after the errant save and the dialog appears as it should.
When going to Save As... (file>save as.. or apple+shift+s) then choosing PDF the "Save Adobe PDF" appears but quickly disappears like it has detected a return. It just saves default settings instantly. It's almost like it is registering a phantom return or something. Go to repeat this process after the errant save and the dialog appears as it should.
Is anyone else seeing this? I looked around the Adobe support website and couldn't find anyone else experiencing this.
We are both using latest/greatest retina MBP 10.8.2 with apple wireless kb/m. I recorded a screen capture of it but this version of vBulletin isn't exactly attachment friendly.
Additional notes:
This doesn't have every time with every file but I have yet to find a common denominator.
The issue(s)
Additional notes:
