Hi all
I hope someone can help me with this.
I work for a publishing firm that sends work to web, flatbed, and recently, gravure presses.
We create documents in InDesign and then export press PDFs to send to the printers.
As part of the PDF export preset we use, Color management (under the Advanced tab) is set to "Leave unchanged" as recommended by the web pre-press people.
We have always used a Euroscale Coated cmyk colour profile.
However, recently we have acquired a publication that is sent to gravure press, and the pre-press people there gave us a new colour profile to use when converting images from rgb to cmyk.
It is called Fuji Color Art 7.2.01. This profile allows the cmy plates of the image to not use UCR in conversion, i.e. the cmy plates are punchy and colour-rich in a way they weren't before.
How this is going to affect our ink limit settings I don't know.
As far as I am aware, InDesign defaults to a 300 ink limits setting, regardless of the makeup of the colour images or swatches created in the program.
Does this mean I needn't worry about there being too much ink on the page?
If I want to create a new preset with this new profile in mind, and set in as destination profile under the Advanced tab will this cause problems?
It seems the colour quality will be better and punchier (and blacks richer?) with the Fuji profile and I begin to wonder if I should use it on other publications too.
Is it possible for me to use the same profile for work being sent to web and sheet-fed presses? Or will this create problems?
I am feeling confused about the best way to approach this issue.
please help if you can
thanks
Karin.
thanks
Karin.
