Rjlitho
Rjlitho
28 x 40 x 10,000 sheets x 75% coverage Divide 1,000,000= 8.4 kg =18.49 lbs .
You do not always need the percentage if you know the square inches .
I t helps to be familiar with how different inks carry density. Colors with lots of transparent white or metallic ten to use more ink.This will get you very close .I also have my crews fill out a ink sheet for long runs to help out with more accurate mileage on the next run and to check how we made with the quoted amount .
