LINES on z6100
jonkovach
Okay all you fellow HP z6100 users! I am getting these lines... I can't get rid of them. They seem to only go through the black... but they affect the edges where the blacks go into other colors. It seems to happen after printing for a little while - it is especially painful now because I am printing a job with all black signs, so the problem kicks up faster than usual.
Temporary solution - clean the printheads through the front panel 2-3 times... solves it for a little bit, but it just comes back. I have enhanced the scans (attached) to show it a little more obvious. My blacks are nice and dark, but these light colored lines run through everything.
Does anyone have any idea WHY this is happening, and WHAT I can do to permanently fix it???
Thanks,
Jon
Andy - Go spam somewhere else bud.... k?
As for your questions, looks like one of two possibilities - one being a dirty head, but I'm leaning more towards ink starvation or an air leak. When you clean the head the damper fills back up with ink, and its fine for a bit, but as your printing it comes back (as either the damper builds suction because of a lack of ink, or it sucks in air).
Now I don't know your printer in paticular, but this is a common problem on most inkjet wide format printers. Not that it happens often, but it is something that can happen to all brands.
Does it happen when your printing light coverage prints?
Are you running the OEM ink or an after market ink?
