Looking Feedback on Capability of Hikari 270 7 U7HLLN,2006
Margaret Lucas
The specifications of the press are:280 mm web width,intermittent,7 colour, with interdeck Hikari UV 9 kw drying power,2 hot foil units, flatbed silk screen- Screen unit is flatbed made by Rapid equipment in Sydney has been retrofitted to the press and has a GEW E-BRICK UV curing unit on it, lamination, flatbed diecutting,rewind/unwind, rapid slitter,servo motor.second pass scanner. Max Repeat:254mm.Semi rotary : 210 mm.
We have a buyer who wants to print Metallic paper self adhesive label, pe, pp, ps based transparent pressure sensitive label, PVC shrink sleeves label.. In roll form.The buyer asks the questions below:
Can the machine be modified to attach chilling drum system ?
Can the machine print PVC shrink sleeves ??
Can the machine be modified to handle cold stamping/lamination ?
We have been told the machine cannot print on film due to the lack of appropriate tension control on the machine.
Does anyone have advice regarding the above. We believe he will need a flexo press with chilled rollers.
Margaret Lucas
[email protected]
