Hello,
I have a Luscher Xpose 160. I was wondering if anyone can give me guidance on how to control the set back in the spool folder. The manual that I have does not define how to do this. I need to match plate position to another offsite Lucsher.
When in the Luscher Q2 Configuration Editor, I have made and tested the new queues. I am able to enter an offset in Process Run menu that will push the image away from the clamp edge. Here is the text line for that: C:\Xpose\bplot.exe -invert -mirrorY -ctp -burnout -position 0.0 0.55
When I try to do the opposite and get the image on the other Luscher to bring the image closer to the clamp edge, I can bring it no further and if I use 0.0 0.0. Here are the test lines I have tried:
C:\Xpose\bplot.exe -invert -mirrorY -ctp -burnout -position 0.0 -0.55
C:\Xpose\bplot.exe -invert -mirrorY -ctp -burnout -position -0.0 -0.55
Both of those gave me the same position as when I just used 0.0 0.0
Any help is appreciated!
RJ
RJ
