Good day
I have been investigating an intermittent distorted image in the rolling direction. (not across the width).
The distortion appears to occur on the last 15 meters of AGFA HNS film. Distortion ranges from 2 -5 mm.
Across multiple rolls of film, I could rule out material to a point.
A previous technician replaced the rubber bands on bottom roller. I speculate whether these are the correct diameter and type of rubber.
Is there a specific diameter the rubber O-Rings should be?
Belts feel tight, nothing else is visibly wrong.
I have to the best of my ability cleaned the rubber bands and sprung loaded pressure roller.
I would suggest that maybe the problem is coming from the input cassette.
Is there a particular procedure for setting tension on the input cassette clutches?
Will have another look at splitting the clutches and cleaning them. All old stuff.
Can anyone offer any other suggestions please.
Colin
Colin
